Hi, thought I'd pass this on as I've experienced a lot of "driver stopped responding" crashes recently whilst tweaking mining settings and trying to view videos whilst mining
I got the info from here but I've compacted it all below.
To test just run the restartgpu.bat file. A Dos box will appear and then DevManView will ask for admin privileges to run, press ok and let it do its thing. The screen will go blank as explorer.exe is restarted int he process. You will need to restart your browser and miner if they were open.
Hope this saves a little time for someone else. Should work for both AMD & NVidia cards.
I got the info from here but I've compacted it all below.- Download DevManView from the bottom of this page and extract the exe to the desktop or location of your choosing. There is no installation and you don't need the .chm file to run it.
- Create an empty batch (.bat) file in the same location as the exe using notepad or whatever you prefer. Copy the following script into the bat file and save as restartgpu.bat (make sure not to save as a .txt file) keep the file open for now.
Code:@echo off echo. echo *** Restarting GPU timeout /t 2 /nobreak >nul devmanview.exe /disable_enable "[B][I]AMD Radeon HD 7900 Series[/I][/B]" echo. echo *** DoNe timeout /t 2 /nobreak >nul taskkill /f /IM explorer.exe explorer.exe - Run DevManView and right click properties on any of the rows that is your graphics card (there may be multiple entries). In the box that opens copy the Device Name: and paste into the batch file you created. See above where I have put mine in bold italics. Close DevManView and save your batch file.
