On a friends recommendation, I spent a whole 18 of my hard earned pounds on this game. However, much to my dismay, I cannot get it to install
I can install the first CD without problem, but as soon as the installer asks for the second CD, it freezes with no error messages / BSOD's etc. I then have to reboot to clear it, as CTRL + ALT + DEL doesn't work
Does anyone play this game and have any idea why I can't get it to work?
I've been checking out all the Guild Wars forums and some seem to have problems installing with overclocked graphics cards, I have a X1900 XT-X which is running stock, but I was wondering if I can underclock it, to see if it is the card causing the problem? I will also download the latest client tonight and see if that works as I only have the CD's at present.
The rest of the system is Windows XP SP2 (with high priority updates @ 27/3/06), a DFI LP NF4 Ultra-D, X2 3800+ @ 2.6Ghz 1.55v, 2Gb G.Skill HZ Ram 260Mhz @ 3-4-4-8, an Audigy SE sound card and a 74Gb Raptor. The system has been primed for 10 hours without any errors and the load temp is 43 degrees, so I've assumed that it is stable.
Edit: I'm also running Catalyst 6.3
