Guitar Hero 3 Controller
14 Jan 2006
Hello, looking for some help,
I want to use my GH3 controller on my pc, will this work using the adapter you can use to play with the controllers on the pc, if it will work will it work ok or will there be lag?
Cheers.
It does work on the PC with the wireless adapter - even the tilt sensing does work :) Not sure if the PC Guitar Hero 3 will support the 360 guitar but I don't see why it wouldn't.
Yup it supports it. Works fine and no messing about either :)
