Guitar Pro users in here....
13 Jan 2003
Going to attempt to transcribe this...
Alirio Diaz playing Seis por Derecho by Antonio Lauro.
I have the sheet music on order (US retailer so it'll take 3 weeks!) but the reason is just to correct any mistakes. However it's initially going ok..
However what is driving me nuts is Guitar Pro 5. I have put down some notes but how do you insert between notes already scribed? I'd like to put in some rests and modify timing after recording the notes.
I'd like to add and remove notes between existing notes but it seems I can't. I hope it's just my inability to use GP5 rather than a GP5 limitation?
Hmm... finally! There seems to be two ways.
Command + inserts.. so in reality that's command+shift+'+' or command+keypad '+'.. I'm thinking I could probably remap the key sequence onto a single key.
I think I can tell that 5.2 is the first mac version!
Now I've got that sorted, I'm finding it pretty good..
on PC "Insert" makes a new note space before the one you have selected and "CTRL + Insert" puts in a new bar :)
