Hi,
I have a friend who is very good at playing the guitar, and now he would like to make a tutorial video. What he proposes is have 3 camcorders/video cameras (some recommendations for what video camera/camcorder to use would also be helpful), taking different shots from different angles, ie one front on (the main one), another on the fret board (left hand), and the third on the strumming action (right hand).
Then he would download the recorded video from each camcorder onto a computer for editing etc into the final product.
Would Adobe Premiere Pro 2 enable him to do the following:
1) Work with all 3 different shots in one window (I believe it does).
2) Allow him to have in the final version, the main front on shot as the main video, then to insert another small video window with a close up of his left hand working on the fret board, ie 2 different angles (front on and left hand) running together at the same time? You sometimes see this effect on DVD music videos of the likes of Eric Clapton etc, you would select something like "MX Multi Channel Video" in the DVD Menu for it.
3) Allow him to output the final version as a flash video (I think it does do this)?
Hopefully I have explained what my friend is trying achieve.
If Adobe Premiere Pro 2 will not achieve this type of video editing, what software could you recommend that would?
As regards the recommendations for video camera/camcorder to be used, nothing to expensive, but something that will give both good video and audio quality.
Any other suggestions would be most welcome.
Many thanks for your help.
