Hi guys,
Over the weekend I was tasked to change the brake fluid and rear pads on my mums Astra G. The pads were easy enough to do (after I had to use a blow torch to remove the stubborn caliper bolt), however the fluid change took a lot longer than I expected.
I used a Gunsons bleeder kit, connected to a spare tyre as per instructions at 20psi. When undoing the rear bleeder nipple I was expecting a rather rapid flow of fluid but all I got was a small trickle. It was literally a 'drip... drip... drip' scenario. I thought perhaps the nipple wasn't open enough but after half a turn it refused to budge. Bleeding the adjacent side caliper, the flow was no better. When resorting to the 'two man' method of pushing the brake pedal down, the flow was nice and quick so I can assume the bleeder nipple isn't hindering the flow in any way.
Her Astra has ABS, and I considered trying a higher pressure than 20psi but having never bled brakes before I didn't want to risk damaging anything by doing so. The Gunson kit seems like a great idea, but if this pathetic flow rate is considered normal then I'll stick to the two man method in future.
Thoughts / comments?
I've heard the horror stories but then I've also read the many praises, who are you supposed to believe? Owing to this I covered the reservoir and immediate area with an old towel just in case the worst happened. Fortunately no bad leaks, but I'm still not liking this kit much!
