guys i think i am having some problems.
2 Dec 2008
Cardiff
my north brinde is burning, its was really hot when i tuched it.
Try HW Monitor or pc wizard as these should hopefully show which is the NB temp.
What board are you using.
its Gigabyte GA-G31M-S2l
also witht the ATX when i conect it i still have 4 small left
should i plug in the small one too???
but i wonder why is my north bridge so hot.
also the other owners of e5200 their JT max temp is the same as core tems. my one is way higher
hot northbridge doesn't mean that something is wrong. it's the same like nobody is touching car's engine to check if it's hot or not.
so until mb is working ok (you can stress it for several hours using some benchmark etc) then you should not be worried
