Gysnc settings for RTX2070 and Hanspree HG324QJB
30 Sep 2006
Midlands, UK
Hi all,
i can't find the gsync settings in nvidia control panel on w10 pro.
I'm running geforce experience with the latest drivers 441.41.
"set up G-SYNC" is supposed to be under the the "Display" tab, but its simply not there on mine.
Is it invisible because i'm using HDMI cable instead of DisplayPort?
As other owners of the Hanspree have alluded to, the include DP cable doesn't work, so whilst i'm awaiting the delivery of a decent one, i'm usinh HDMI.
Freesync is ON (in monitor settings) and i get a "144" top right of the monitor and nvidia is set to 2560x1440(native) @ 144hz.
Is there anything else i'm missing or should be doing.
Thanks for any advice offered.
Yes it will only work over displayport and you need to have freesync enabled on the monitor
Thanks. Freesync is certainly enabled in the monitor settings and i'm awaiting the delivery of a decent quality DiplayPort 1.4 cable (backwards compatible as the port is only 1.2 on the monitor).
So, hopefully as soon as i plug the new displayport cable in i will see the gynsc option in the nvidia display settings (?)
