H100 airflow
15 Dec 2010
Hi,
How should I set up the h100 in my 650d case? I was planning on keeping the top fansl as exhaust but I have read reviews saying I should have it as intake?
Is there an example picture on the corsair site? They show a 550d with the h100 installed. Fans mounted to the top of the case sucking air in through the rad, then the rear fan sucking the hot air out.
I just have the H100 set as an exhaust in mine, reason being is that hot air rises and all that. I don't think there will be much of a difference in temperature.
I have mine set to exhaust.
If you use it as intake then you'll get dust in your case without dust filters like I did with my H50.
