H100 currently in push, want to push and pull
17 Apr 2012
Hello.
So I have my nice new beautiful Corsair 540 Air case. Love the design and the cable management. Haven't even had to use any cable ties!
I have my H100 setup with x2 Corsair Sp120 Quiet Editions currently fed from the water pump block over the CPU. I would like to install another two on top of the radiator pulling the air through. However I am not sure if I need extra screws to hold the new fans to the rad and the then the fans to the case?
Also I have noticed there are an additional two fan connectors (or so it appears) on the H100 block. Can I use these for the extra two fans?
Can someone advise me on what I need to do?
Thanks,
Alex.
Hello.
Thanks,
Alex.
Just add 2 more SP 120's and do this :)
https://www.youtube.com/watch?v=Ntk9d_Nxpzk
and you can use the H100 head to control the fans if you want to as it is designed to do this anyway.
