h100 fan config
10 Jan 2009
London
hi just putting together my new pc and stuck on the H100 cooler install on my 800D case
should i put the fans above or below the rad and should they be pulling air in from the outside or pushing it out from the inside.
seen loads of threads on the net but they say its based on case airflow and stuff.
thanks in advance
I have 4 fans on my H100 pushing air out the top of the case. Its not as good as a custom water loop but my H100 can cope with my hex core at 5.0ghz.
