H100 question
Should be fine: Top: 230 x 30mm standard fan x 2, 700 RPM, 19dBA (included)
(can be swapped for three 120mm fans)
Room there for a 320mm rad, so the H100 240mm should be fine!
thanks
Ekkkkkk just looked on corsair's forums dam there are a lot of H100/H80's failing think I will give them a miss.
