H100 replacement fans
13 Aug 2012
Boston,UK
For my next build I want to buy a H100 cooler.
I currently own a H80, but with only one fan as an intake.
If I buy the H100 for my new case I want to use a Push/Pull.
What fans could I replace the Consair original fans with to keep the same
performance and lower the noise a bit?
Cheers.
I picked up a couple of these:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-032-NB&groupid=701&catid=2331&subcat=4
I can't reccomend them enough - they are superb. I know they're not nececarilly designed for radiators but they are doing an excelent job. They are completely silent at all times with the H100 on the middle setting and keep temperatures lower than the stock fans - there really is no comparing them (or any decent fan) to those god-awful stock fans. The pump unit itself, however, does make a slight noise, but I can live with it.
I only have 2 so as for push/pull, I couldn't say. But if you want silence, go for these. For maximum cooling performance, Gentle Typhoons are reccomended by everyone in the world so buy a couple of those.
