- 10 Nov 2012
- Down the road from Diddly Squat Farm
Anyone using the H100i on their 5930K?
How does she do?
How does she do?
Just purchased a H100i with my 5930k so will let you know when I overclock, at the moment I seeing high 20's idle and high 50's under prime95 load with a stock CPU.
Any feedback B2K? I am considering getting a H100i+5930k and WCing at a later date
In the olden days, the comparisons always showed AIO coolers were no better than top air coolers (for heat dissipation or noise). Is there something about the heat output by these new Haswerll-es that suggests an AIO would perform better than the top ends air coolers.
i really want to know this too.
Pretty sure no high end air cooler keeps up with a 240mm radiator AIO cooler these days, without having delta (insanely loud) fans on a huge monstrosity of a heatsink (which could bend/crack your motherboard over time)
I forgot about this thread. Well mine is still stock and idle sits about 30 degrees and about 405 under load.
405 !!!!!!!!!!![]()
