Just purchased a H100i but have been hearing stories about how noisy the fans are. Can anyone suggest quieter, but with at least the same level of performance? Thanks
Quieter is possible, same performance is not. These fans have very high static pressure which i have not seen matched. I would suggest testing the fans before replacing. If you are not going to push the system with a high OC then it would be possible to compromise on the performance for the reduced noise.
This is the fan spec for reference.
Rated Voltage 12 V*
Voltage Range 5.0 V ~ 13.2 V
Starting Voltage 5.0
VDC*Rated Current 0.35 A*
Rated Power Cons 4.32 W*
Speed 2700 +/- 10% RPM*
Airflow 74.42 CFM*
Max Static Pressure 4.82 mm-H20
Noise Level 37.68 dB(A)*
Life Expectancy 50000 Hours @ 40 °C
