H100i RGB platinum owners, help.
6 Oct 2007
Liverpool
Hi,
I have the H100i RGB platinum (2 x ML120 fans), and the Corsair 220T Airflow (3 x SP120 RGB fans with a Lighting node core).
Has anyone else noticed a difference in the colours output by the ML120's fans on the AIO?
They are a very different shade to the SP120s especially when using the brighter colours!
I found another thread who had the same issue, and suggested the H100i was the problem and after pluging the fans into other RGB headers it matched the same shade as the other case fans.
It really does feel/look like the H100i just isn't sending enough power to the fans LEDs.
Wondering if this is common or I should (if i can be bothered replacing it) RMA it.
Thanks
Is this because of the lower number of LED's in the ML fans?
I swapped mine out for LL's instead as the fan types have to be the same on the Corsair hub. I have a total of 6 LL's in the case now and everything looks fine.
I don't use SP's
