- 9 Jan 2010
- Sunny Brizzol
Afternoon,
Put me new-ish rig together on weekend, its an i7 4790K, Asus Maximus Gene VII, G-skill 2400mhz Ram, Corsair 650w PSU, Sapphire 290X GPU, Corsair H100i cooler
So all put together and running, first wanted to get the RAM working at its spec'd speed before OC'ing the CPU so leaving all CPU voltages at auto (besides ram) I run IBT and AIDA64 and I was seeing 75-80 degrees on hottest core in IBT and 70 in AIDA and I thought damn that hot considering the H100i is supposed to be good!
I then done a mild overclock to 4.6ghz with a 1.23v core and in IBT was hitting 90-95 degrees and 80-85 in AIDA
I stopped stressing it straight away when I seen those temps, I removed the H100i and then used some IC Diamond TIM and temps have dropped a few degrees but to me they are still very hot!
I installed the Corsair LINK software and can see the pump is running fine etc so not sure what's going on, the radiator barely gets warm when stress testing and I expected it to be much warmer so wondering if I have a defective H100i?
Anyone shed any light on it or things that I can test?
