- 22 Feb 2010
- Southampton
I have the h100i V2
my motherboard only has 1 PWM connection (CPU header)
can i use this Pwm splitter
https://www.overclockers.co.uk/akas...-5-pwm-case-fans.-ak-cbfa03-45-cb-070-ak.html
to split the cpu header for my 5 PWM fans (powered by the molex)
and then connect the h100iv2 3 pin waterblock cable to a normal (3pin) system fan header ? (the system fan header doesnt have any voltage control but then pump needs 100% of the 12v anyway?)
thanks
thanks
