H100i V2
27 Dec 2013
I have just installed the Corsair H100i V2 CPU cooler into my machine.
After booting it for the first time there is a constant clicking which I initially assumed was bad cable management. Checked all cabling and listened.
The noise is coming from the pump unit itself.
I am using Corsair Link. FYI clicked was present before installation of Corsair Link.
The clicking itself doesn't seem to affect the unit.
CPU Temp : 26.4
CPU Fan RPM : 780
Pump RPM : 1950
Is there possibly something I'm missing with the installation or within the BIOS?
Any help would be appreciated.
Are you running AI Suite at the same time as Corsair Link? They tend to step on each other. It states this on the corsair website FAQ.
Interesting...I was running then in tandem and never noticed an issue. I would however suggest to the OP that once you've updated the firmware, create a 1-1 fan profile.
