H105 Flashing?
29 Jun 2005
My H105 white backlight that lights up the "Corsair" text is flashing, is this correct? Seems to be in line with the pump pulses or fairly rhythmic though I have seen it quite random at times.
If I set all the fans to max then it glows bright and stops flashing so assume its directly connected to how much power it is getting? Just a little annoying that is flashing.
After I switch fan speed to max then lower it again it will some times go back to flashing or sometimes dim but the light stays solid...
Thanks
moeh
does cooler that use the corsair link software ? my h100i had a option to make the leds pulse and to glow brighter when temps rise think it goes off completely at idle , i had my pwm fans connected to the motherboard though
Disable any CPU fan (if thats what the pump is connected to) control options in the motherboards BIOS, feed it full power 100% of the time.
Thanks all!
I have an Asus board and so I have to set a profile to the fan? I selected Turbo and it seems to stay on though is quite loud. Temps seem better though so guess my Corsair pump was just on very low.
Is the Turbo thing the best I can do to make sure its on full power?
Cheers
moleh
