I've currently got my H105 shoehorned (almost literally - it's at an angle and held in with 2 screws instead of 8) into my Corsair 230T which means that even a trivial task such as replacing my RAM is a major pain as I'd need to remove the radiator first. It's also probably not doing my chipset heatsinks any favours as it's right up against them.
The NZXT H440 (2015 edition) has caught my eye but I've read that installing a radiator into the top isn't up to much due to poor airflow.
Can anyone confirm how bad it actually is?
I'd got a Tri-X Fury which is some 310mm length so I'd need to remove the cage anyway, which brings me to...
I've got 3 SSDs and 1 mechanical drive, is there a way to hold my drives without the cage?
