I've gotten as far as this:
Asus Maximus vi formula - 4770k processor - ax860 all connected.
AIR540 - 3xAF120's in front of case, 1xAF140 in rear
H110i - installed with 2xSP120's replacing the supplied fans.
Im a little confused as to the best way to control the fans. The H110i comes with link software, i believe, but this cannot be used at the same time as the motherboards - fan xpert2.
So is it best to run all the fans off the motherboard? (if so, it looks like Ill need a splitter cable to attach both fans to the CPU_OPT connection, as the supplied splitters have a special connection to be plugged into the H110i itself).
Also is the board actively monitoring temps, so it can control fans, or am I supposed to be using sensors?
Finally, I also have a bitfenix recon fan controller. It can control 5 fans, (the two on the h110i would have to be split again) and comes with temp probes. Would I be better using this controller? I'm not entirely sure where to best place the probes, but would this hardware controller be a better option?
Im sure this isn't much of an issue to those who have built a few pc's, but I've managed to overthink myself into a corner. A little guidance would be appreciated. Thanks
