Being on carpet does not mean bottom intakes can't be used. Simple solution is to put case on an open center castor base with not only raises case up a little more then caster size (most common is 40mm .. I often use 30mm) it also makes case much easier to move.
Radiator in front means everything being cooled by front intakes will be using pre-heated airflow coming through radiator .. not really a logical thing to do with everything air cooled with heated air in order to lower CPU temps a couple degrees at most.
Radiator in top with good front and bottom intakes means GPU heated air moves back and out open GPU slots and other rear venting while cool air from front intakes pushes heated air back and their cool air goes up into radiator.
If you are looking at CLCs, I suggest you look at AIOs that are not CLC for similar or slightly more money like be quiet! Silent Loop, Fractal Design Kelvin or Alphacool Eisbaer. Much better construction with copper radiator, more powerful pump, real fittings and hose that can be cut to length, replace parts or to expand system as needed .. and a fill port to top up / change coolant in a year or two .. and all liquid cooling needs to be maintained by at least topping up coolant occasionally. It's the next biggest reason CLC pumps fail after poor quality .. maybe 1st reason most fail.
https://www.overclockers.co.uk/b-gr...perior-liquid-cpu-cooler-240mm-bg-10g-bq.html
https://www.overclockers.co.uk/be-quiet-silent-loop-superior-liquid-cpu-cooler-280mm-hs-016-bq.html
https://www.overclockers.co.uk/b-gr...in-s36-all-in-one-water-cooler-bg-01m-fd.html
