H150i Capellix and P600s case
28 Feb 2015
Hi all,
I was just wondering if the 360mm H150i capellix would fit front mounted with tubes down in a P600s case?
FYI: GPU is an asus tuf 3070
Thanks in advance
The tubes are 400mm long but im guessing if i said it would fit tubes down. Tubes at the top of the rad is ok as long as the cpu block is lower than the top of the rad.
