h20 cooling kits which one
28 Apr 2006
gigabyte mobo GA-K8NF-9-Ta
xfx 7900gtx running now at 700mhz/1800 up from basic stock settings
cpu 3800*2 not oc as yet
may also purchase ausus sli board
looking at the kits on the web site lots to choose from a lot r out of stock
any suggestions on which way to go?
case cutting no problems.
thanks
Phil
this should really have been in the overclocking aand cooling forum, but i doubt it wont be long until itt is moved
'kits' tend to be ... well not very good. many people here will tell you that you are a lot better off building your own 'kit' from individual components.
after all if you buy a 'kit' all your doing is buying your components in one box instead of several !
a budget would greatly help as a WC set up can go anywhere from £50 to £400+
Swiftech H20-120-FK Watercooling Kit (Socket 478/754/939/940) (WC-011-SW)
With whatever gpu block fits your card. Ignore the chipset.
