hey guys,
been thinking about experimenting with watercooling for a while now, and just put this little basket together to get a rough idea of costs,
is there anything that you'd change, and have i spec'ed enough fittings? tubing?
just want for the cpu at the moment, gfx might come at a later point when i get a bigger case
also, just for a basic cpu loop, would you spec a reservoir, or just do without.
whoops forgot a pump haha
http://www.overclockers.co.uk/showproduct.php?prodid=WC-004-SW&tool=3
2m will be plenty
it claims to have better electronics and reliability. I got one but can't comment on either as my loop has been up for all of 2 days now
