Right, I thought I would give watercooling a go in my Shuttle SN45G. One thing to note is that I'm going to try and do this without mutilating the case. Firstly I don't have any tools to start drilling holes in my Shuttle and secondly, I don't trust myself to do a good job.
I've done watercooling before, but that was in a Coolermaster Stacker which has slightly more space!
Here's a few pictures of my SN45G before I started - http://clwn.co.uk/shuttle/
I started by removing all the wires and taking out the motherboard just to see what I was working with. Underneath were some motherboard raiser screw things where the CPU cooler mounts. They were just the right size for my Swiftech Storm fittings so I'm going to take a short-cut and just screw it into that.
This is where my first problem arose. The motherboard northbridge heatsink is in the way!
My question to you guys is: Is that heatsink necessary? If I have to have cooling there, are there any low profile NB Heatsinks that you can recommend?
