Hi,
I recently purchased a H50 cooler for my system and temps do not seem to be great. I was wondering if I could get some advice on these and see if I have installed it incorrectly or if this is normal.
The system is i7 920 OC to 3.33Ghz. The temps as they stand are Idle:35C Load: 60C.
I reseated the cooler and this had negative effect and temperatures jumped up. I did this a number of times and still no improvement. I then applied some AS5 and reseated and still no improvement.
I've moved the radiator to the front of the case and placed a push/pull fan configuration on it but this has not helped. Single fan or double has no effect.
System temp seems high as reported by Speedfan which is 50C but this I believe is due to the graphics card which idles at 61C.
Any advice would be appreciated.
