Hi
Was wondering if it is worth getting a better 120mm fan than the stock one that comes with the H50. The stock one is pretty good at pushing air into the rad but would i notice a huge difference with a better fan?
ie more powerful = lower temp?
If so what one is the most popular or what you would recommend? Not really familiar with the names? Apache ? Noctura? Gentle Typhoon? I have a push/pull setup.
Cheers
Cheers
