23 Mar 2010 at 21:47 #1 Wildego Wildego Associate Joined 5 Mar 2010 Posts 21 Is it worth re-fitting the fan that I took off to fit the h50 and run both? Lian li pc-p80b armorsuit. Cheers!
25 Mar 2010 at 08:19 #3 Amidar Amidar Soldato Joined 15 Jun 2003 Posts 2,622 Location Darlington If you fit another fan it really needs to be identical to the allready supplied corsair fan,best to fit a matched pair of fans.
25 Mar 2010 at 17:21 #4 Danm54 Danm54 Associate Joined 20 May 2009 Posts 1,857 See the massive 53 page thread on the H50, a simple search would give you this and save you asking surprisingly common questions.....
