h50/h60/h70
8 Apr 2009
Tavistock,Devon,England
i am using a h50 now and just been thinking, is there any diffrence proformance wise between the 3? or can i make my h50 better by adding a 2nd/better fans ect?
I run a H50 on a stock fan, How ever i have just placed a order with OCUK for a Viper fan to replace the stock fan, Looking about it should shave a 3-4c off full load temps and even more if you run push Pull.
Take a look at the H50 vs the H70
You only really see a significant improvement in temps with the H70 over the H50 until full load.
The 6 series Corsair comes somewhere in the middle.
i have the h60 , i swapped out the stock fan for a viper and temps dropped by a couple of degrees. but it was much louder , so i swapped it back . didnt think the drop in temp was worth the extra noise.
