Makes sense.Fans will be matched so no diff in speed or airflow so should be more efficient than mixing fans......
Didn't expect it to be that much. Definitely buying.You should get at a least a 7*c decrease in load temps
I've got this case
It's only got a small amount of room at the back for exhaust so the more air I can shift the better.
I have the same setup as OP is buying/bought and it lowered the temps by 8 degrees from the stock H-50 fan.
Lol crap! To the poster. I removed the stock fan & added two high performance fans in push/pull. It made very little difference. 1-2C maybe. Many people only got this improvement, check reviews. These claims of 7-8C difference have been smoken something or done some serious mistakes.
Just because you didn't get a significant temp drop, doesn't mean others don't.
