H50 + NZXT BETA wont fit becuase of PSU. any ideas
27 Sep 2009
Hi there
I can fit the rad to the back of the case becuase it hits the power supply above. so the holes on the rad dont line up to the ones on the case.
Is there any way i could get round this apart from chaing to the antec 300 which i have as well
thanx in advance
Yes.
Attach it to one of the fan spots on the side of the case. Just make sure you remember it's there each time you're removing the case side to fiddle with things.
Couldn't you mount it outside the case? Or would that mean having to dismantle it? I assume you've tried it at different orientations?
hi super.
im afraid the only option seems to be on the side. mounting it outside would mean taking the h50 apart and i dont think anybody has done that
