h50 (Rev1) Pump barbs
24 Feb 2011
Hi All,
Modding a dead h50 to fit into my WC loop to cool a GPU (460 NonRef).
I've stripped down the pump/block and managed to snap one of the compression barbs that slot into the back of the block.
They look like compress fitting which slot in and are held in with a screw plate above.
Anyone know the exact size of the original barbs (which were plastic) or metal replacements which I can order ?
I Want to replace both of them ideally with a 1/2' ID barb.
Cheers
