- 27 Feb 2009
- Among the living
Hi,
I've hooked up a H50 to my i7 920, the problem is i've been getting bad temps around 67-70 on full load on 4 cores with 3.2Ghz. Some people are saying its bad some are saying its ok.. but i think its bad.
Im using the stock one that came with the H50 and its mounted in a 800D case as well.
Just getting opinions on what way should the fan blow? Out of the case or into the case? Just now i changed it so that the fan blows out of the case, there was a lot of dust as well don't know if that was causing bad temps because of the fan blowing into the case.
Any ideas?
Thanks
Any ideas?
Thanks
