H500P Mesh Optimal Fan/Airflow Help
17 Nov 2020
I have an H500P Mesh case with the stock 2x200m fans as intake on the front, the stock 140mm fan as exhaust in the rear and i also have an 240mm H100i RGB Platinum for my CPU (radiator is at the top as exhaust)
My first question is i also have an empty Corsair SP120 iCUE fan that i've mounted next to the 240mm radiator (to the front side)
I've mounted this fan as an intake and wonder if this should be an exhaust or simply not be there at all?
Another question i have is the top panel blocks a lot of airflow, air can only go in/out through the small mesh holes on the sides therefore the fan is SP series as i've thought the AF models will simply not be efficient. Is this assumption wrong?
Thanks.
