H60 Fan screws
8 Jan 2007
Essex, Canvey Island
As the title says I would like to know what the screws are which attach the fan to the radiator and where I could possibly get them from. Tried contacting corsair support but haven't been that helpful. Need some more because I am running push/pull and only have 2 in each fan right now.
Thanks
Lewis
To be honest 2 for each seems reasonable for the small rad, it's not like the screws will break off or anything. Large paintings are commonly held by a lonesome screw.
Wouldn't it be the same as the H50? shed load of posts on the net about the size, problem is it's american sizing.
Normal case screws are the same size but not the same length, I have two that support my H50 fans from the outside of the case.
If not I'm sorry was just taking a stab in the dark here.
Assuming these are the same size as the Antec ones,
You require some UNC 6-32 screws, which fall between M3 and M4. The length of course depends on the thickness of your fan and whether you will be pushing them through your case.
You can of course use two for each fan as you are now.
