H60 Push And Pull Configuration Which Way
6 Apr 2009
Liverpool
quick question on push and pull do you pull the air from outside the case blowing into the case or from the inside blowing out like a exhaust or do you just see which works best for you ...thanks
The direction should be to pull cool air into the case; through the radiator. Helps if you have a fan pushing used air out at top of case also.
On my 620 push/pull setup, I have the air being pulled in from the out side.
Like nuttyprot say's, helps if you have a fan pushing used air out the top of the case also. I have 2 140mm fans drawing air out the top of my case.
If your case air flow is ok, inside blowing out as you are heating up the inside of the case with hot air from the radiator blowing in.
ok ive been playing around with it both ways ...had it from inside first like you do with exhaust fan....so changed to the other way....its about 1c difference on idle....but slightly higher on load...but what it has done is when i had one fan on its dropped by around 5c
