h6o buzzing noise???
30 Aug 2011
up north
my h60 has developed a buzzing type noise but only at idle..
any ideas whats caused this or how to fix it???
its cooling a 2600k @ 4.5...
Probably from the pump, could mean its on its way out. Fairly certain they accept RMA if the pump is buzzing...
Some come out of the box like that unfortunately, get in touch with corsair and see what they have to say.
Shouldn't be, its sealed. I did read some times these ALC units can get a 'sticky' pump resulting in strange noises. Just keep an eye on your temps, as long as they are fine you have nothing to worry about :)
