It has been suggested that I should plug the pump cable for my H70 into a molex adapter, instead of into a jumper on the mobo (via OCUK Support), as this "might" improve my cooling performance.
So, I have a molex adapter, but I'm not sure if it's suitable.
The cable on the pump is "3-pin", and whilst the molex adapter is designed for 3 pin male sockets, if you look inside, there is only 2 contacts.
I am been "scared" to try this, just encase it doesn't power the pump correctly, and I damage the CPU.
Any advice?
Any advice?
