H70 Pump : Running?
18 Oct 2002
Cambridge, UK
Hi,
I've got 1 x fan and the H70 pump (I'm right in thinking the pump is contained in connected to a SYS_FAN1 on my Gigabyte P67A-UD3-B3, the fan is running but I can't hear the pump.
Temps seem fine but I guess I'd thought I'd hear the pump running?
Cheers
HEADRAT
Hi, the pump needs 12v to work properly have you got a power header as they supply 12v, the pump on my H50 was very quiet.
Gotta admit i just installed same cooler today and thought the same, but after putting a nice OC on it and seeing great tempts it must be doing something ;)
Hi
Can anybody recommend so quieter fans, for the radiator, the Corsair ones seem unnecessarily loud!
HEADRAT
If you're looking around the ~£10 the Akasa AK-FN057 Apache Super Silent 120mm Fan are good value i would also recommend Sharkoon Silent Eagles.
