I replaced mine with:-
2 x Akasa AK-FN059 120mm Ultra Quiet Viper Cool Fan
which I found quieter and dropped my temps.
I've got a H70 and with a I7 2600K @4.5Ghz (1.35v) running Prime95 for 4 hours my average temps are about 70 degrees.
I just got one of these:-
http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK&tool=3
HEADRAT
You plug one into CPU Fan MOBO header, one into a MOLEX, then you have 3 spare connections for fans.
Looks good to me, BUY![]()
I have a lapped True 120 Ultra and was considering to get an Antec KUHLER H2O 920 for £64 delivered, would it be an improvement over the True, or not?
I'm planning to get the new FX-8150 and overclocking it, will the Kuhler cool it better than the True or not with respectable noise levels.
Noise will be an issue and the fans will be getting turned to their lowest settings when in stock mode.
As my True has a single fan with an exhaust on the P180, with the the Kuhler having two fans, I will be replacing these fans with the two apache's currently being used.
Any help?
Leaving the vcore on auto will be fine for the majority of sandybridge overclocks, so just increase the multi. But how high are you planning on taking the chip? as 4.8ghz and above is really where you need to start setting a manual vcore.
Also what vcore is required for a set speed changes from chip to chip, example at 4.8 I'm nearly stable (requires a few more hours prime) at 1.312v, while leeroy on here can only get stable at 1.46v. Luck of the draw
