H80 or H100?
17 May 2013
West Sussex, UK
Right, thinking about getting one of these AIO coolers (The refurb units). The H80 will fit in my case fine, but I'd have to do some modding to fit the H100. This isn't a problem, but is it worth it?
As the H100 has double the capacity, and double the fans, is it twice as good?
Is the H100 worth the extra £5 or so and a bit of case modding? Or is there little difference in their performance in reality?
Depending on your case, if you don't mind modding i would go for the h100. Performance is similar but the h100 is marginally better. The h80 radiator is quite thick and depending on where you mount it, might get in the way when it has fans on it, while the h100 is fairly discrete.
