Hi Guys
I turned my PC on this morning and straight away noticed an increased fan noise from my CPU cooler - I checked my temps and @ 0% CPU Load my temps were approx 60c across the 4 cores - measured on AIDA 64
The fans were both spinning and blowing cold air into my case and the cooler was lit up - I checked all the cables they were fine
I restarted my comp and it wouldnt post - it said cpu fan failed.
I rewired the power from a new molex from a new cable off my psu and the same happened - cpu fan failed
I restarted again after looking into the bios settings it posted fine and my temps are back to normal, therefore I assume the pump is working now.
I have emailed Corsair support but thought I would check on here to see if anyone has had anything similar happen to their H80??
