Excuse me poor knowledge on this, but looking for some clarification.
I have a H80 and last year replaced the standard fans with Noctua NF-P12s in push/pull. They do a great job and cut the temps by miles, also enabling me to turn the H80 to max setting without it sounding like it was taking off (like the standard fans).
However it's not quiet enough still. The other day I thought I'd switch the H80 to it's second setting to calm it down, but nothing changed?
Is this because the Noctua NF-P12 are 3 pin fans and not PMW? Am I right in saying that they are one speed only, whereas PMW is variable?
Also, if I fit PMW fans, connect them to the H80 which then connects to the CPU Fan header, will they change speed with CPU load? Or only if I change the H80 speed setting?
Oviously in an ideal world I'd like a set up that stays whisper when quiet when browsing but gives it the beans when it needs it, without me touching anything but struggling to work out how I get there? if at all?
Thanks in advance
Thanks in advance
