- 28 Sep 2008
I've had my h80i for about 2 months now. I've been monitoring the temps at idle and on load.
I used to have the h50 before I upgraded. Never had a problem with overclocking my CPU to 3.2ghz (using the default overclocking profile settings). I used to be able to get 3.8ghz easy using custom settings.
But with the h80 I can't seem to get any stable temps. Currently I sit around 50-54 on idle. If I run prime it just goes straight up to over 90.
Has anyone else experienced these problems?
Thanks.
Thanks.
