Hi guys
I currently have 2 x Juniper SSG20's and I want to play around with the HA capability (NSRP?) as I'm thinking of running 2 x BT Infinity lines into my garage, has anyone configured HA on these and if so do you need a specific license for it?
I think my license is the extended license, so it should be good to go (I think):
Sessions: 16064 sessions
Capacity: unlimited number of users
NSRP: ActiveActive <<<<<<<<<<<< this is the bad boy I presume?
VPN tunnels: 40 tunnels
Vsys: None
Vrouters: 4 virtual routers
Zones: 10 zones
VLANs: 50 vlans
Drp: Enable
Deep Inspection: Enable
Deep Inspection Database Expire Date: Disable
Signature pack: Signature update key is missing
IDP: Disable
AV: Disable(0)
Anti-Spam: Disable(0)
Url Filtering: Disable
What's the deal here with NSRP?
Thanks
Vsys: None
Zones: 10 zones
VLANs: 50 vlans
Drp: Enable
IDP: Disable
AV: Disable(0)
Thanks
		 The NSRP lite must only apply to the earlier low-end Netscreens.  Just checked on a base license SSG20 laying around here:
  The NSRP lite must only apply to the earlier low-end Netscreens.  Just checked on a base license SSG20 laying around here: Netscreen/SSG is simple though.  I've got some good guides if needed.
