- 3 May 2004
- Kapitalist Republik of Surrey
I used to like Epson printers because the ink used to be cheaper and back in the old student days you could refill the cartridges yourself. The head is in the printer instead of in the cartridge. Less waste each time etc etc.
I'm rambling.
I don't use my printer all that much and basically whenever I do I find it's missing lines or a colour is blocked and I have to go through the head cleaning procedure. I couldn't get the old printer to clear so I ended up buying a new one. Now the new one has done the same. I've emptied a whole set of cartridges through it now, at great expense, and basically after 6 months owning it I'm going to have to dump it
I tried to strip the old printer to get to the head to clean it with a swab but this was nigh on impossible so I'm not prepared to go through this again.
Is there any easy way of cleaning the print heads out to make them work again?
Do these type of products for unblocking actually work or would I be better off just swapping to an HP printer which has the head in the cartridge?
I'm rambling.
