HAF 922
25 Jul 2009
England
As some of you may know I bought a noctua heatsink and fan and it won't fit my case. I could do with a new one anyway.
I have been offered a HAF 922 for £60 brand-new. Its just been sat in the shop for a while.
Worth buying?
They are a decent case if you like that style, good cooling and more than enough room for your new cooler..
Shame the inside is not black though. :(
I was going towards a more clean looking white case but there quite expensive and I know the lad in the shop quite well so I might just get the HAF 922 for £60
If you want white, you could get a phantom 410 or H2 (both NZXT) for £80ish
or for £100 the Corsair 500R (white).
They'd be my choices.
I would have suggested the new NZXT 230 but is CPU clearence is 158mm, the D14 is 159mm. :eek::eek:
