Haf 932 case mod
8 Aug 2009
Just about to spray the inside of my case.
Instead of re riveting I'll be using Stainless M3 domed capscrews with nylocs And countersunk cap screws for the flush fitting. Any one got any advice for modding this case. Just bought two of these Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fan for push pul on my cpu cooler. Any thoughts on modding my case.
I found the inside of this case was good so i didnt need to mod it for cable`s and so on just a nice red and black :)
Inside matt black powdercoat with plasti kote fire red.
Thought about powder coating mine at work, but we don't stock the matt finish, gloss only got 30 different colours though. So it looks like the spray booth for me as i wanted matt black. Thought about making a new back panel and mother board panel and raising them in the case as i wont be needing the space above for water cooling ,there fore giving me more room above the power supply. Maybe make it 8 expansion slots at the back while I'm at it.
nice mod, very red! I like red and black colour scheme :)
have you braided a 24 pin extender?
Would be interested to see pics of the cable management from behind the motherboard tray!
Yes i braided the 24 pin the reds not so good tbh so i ordered some murder mod red to re do it later on,piccys of the back coming up,i will say this for the HAF you can hide cable very easy with it.
looks nice, I like the cable management hole in the CD drive bays, neatly done!
My colleague (Defiant83) has some of the red MDPC braid, it looks really nice!
BTW incase you didnt know, Murdermod gets its braid from MDPC-X which is based in Europe so you can save some pennies and get it from there :)
